Display individual IPv6 DHCP Relay statistics for specific ports to manage network performance. You can also create a graph of selected statistical values.
- On the Device Physical view, select a port.
- Select the DHCP Relay tab.
- Select the Interface tab.
- Select the interface on which you want to view the IPv6 DHCP Relay statistics.
- Select Statistics.
- Select one or more values.
- Select the type of graph.
Statistics Field Descriptions
Use the data in the following table to use the Statistics tab.
Name |
Description |
NumRequests |
Shows the number of DHCP and BootP requests on this interface. |
NumReplies |
Shows the number of DHCP and BootP replies on this interface. |
